1983 R80ST Rebuild For Charity Project Journal
1983 R80ST Replace Connecting Rod Crankshaft Bearings, Measure Crankshaft Journal
Since this bike sat for more than 25 years and I found water in the oil pan, I replaced the connecting rod bearings. The bearings were in good condition and the crankshaft journals were not rusted and were well within specifications, so that was a relief. I replaced the bearing shells anyway rather than reuse the original ones that had 64,000+ miles on them.
You can read about how I do this work and see a short summary video here.
<ul class="children">
<li class="page_item page-item-10154"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/11-bmw-1983-r80st-replace-connecting-rod-crankshaft-bearings/">11 BMW 1983 R80ST Replace Connecting Rod Crankshaft Bearings</a></li>
</ul>
<strong>VIDEO: <em>1983 BMW R80ST Replace Connecting Rod Crankshaft Bearings</em></strong>
1983 R80ST Install Alternator, Diode Board & Electronic Ignition Sensor, aka, Beancan
I replaced these components with new ones supplied my Euro MotoElectrics at no cost to me in support of my goal to auction this bike and donate all the proceeds to the Motorcycle Relief Project. EME has been very kind and generous to me on this project.
I installed their new Type 1 charging system kit, the <a href="https://www.euromotoelectrics.com/product-p/edl1-107.htm" target="_blank" rel="noopener">EDL-1 107</a>, which has all the parts to replace the stock 240 watt charging system including a new front crankshaft seal.
I also installed their <a href="https://www.euromotoelectrics.com/product-p/beancanreman.htm" target="_blank" rel="noopener">remanufactured electronic ignition sensor, aka, the "Bean Can"</a>, and a new ignition system sub-harness.
You can read about how I did the work and see a YouTube video.
<strong>VIDEO: <em>1983 BMW R80ST Install Alternator, Diode Board & Electronic Ignition Sensor</em></strong>
This is what I started with.
<a title="Under The Front Engine Cover" href="https://www.flickr.com/photos/brook-reams/51970514915/in/album-72177720297720977/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51970514915_e6218830f8_c.jpg" alt="Original Engine Electrical Components Under The Front Engine Cover" width="800" height="600" /></a>
<a title="Diode Board Wires: (Left) Alternator "Y" Terminal; (Right) DC Battery Charging Wire" href="https://www.flickr.com/photos/brook-reams/51970020573/in/album-72177720297720977/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51970020573_e0c2da67ce_c.jpg" alt="Original Diode Board" width="800" height="600" /></a>
<a title="Original Alternator" href="https://www.flickr.com/photos/brook-reams/51970020603/in/album-72177720297720977/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51970020603_4286b1e804_c.jpg" alt="Original Alternator" width="800" height="600" /></a>
Original Alternator
<a title="Remove Bean Can" href="https://www.flickr.com/photos/brook-reams/51989122064/in/album-72177720297720977/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51989122064_a129dcdfa8_c.jpg" alt="Original Bean Can" width="800" height="450" /></a>
Original Bean Can
And this is the final result.
<a title="All Done" href="https://www.flickr.com/photos/brook-reams/52050469196/in/album-72177720297720977/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52050469196_79ff327000_c.jpg" alt="All Done" width="800" height="600" /></a>
All Done
1983 R80ST Cylinder Measurement & Honing
This bike has the Nikasil plated aluminum cylinders. Nikasil is a nickel silicon carbide material that is extremely hard and wears very little and can be platted onto aluminum. That said, I want to measure the cylinders to determine if they are in good condition since the bike sat for about 25 years and had 64,000 miles on it.
<a title="Insert Bore Gauge Into Cylinder & Align With Top Measurement Circle" href="https://www.flickr.com/photos/brook-reams/52096762354/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52096762354_4f146dc7ce_c.jpg" alt="Insert Bore Gauge Into Cylinder & Align With Top Measurement Circle" width="800" height="450" /></a>
I previously measured the cylinders on my 1973 R75/5 and you can see that procedure here.
<li class="page_item page-item-2062 current_page_item"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1973-bmw-r755-rebuild-project/11-bmw-r755-cylinder-piston-and-ring-measurements/">11 BMW 1973 R75/5 Measure Cylinders and Install Pistons & New Rings</a></li>
</ul>
On this bike, I measure the bore, ovality and taper using a bore gauge to see if these cylinders are still serviceable. I found Both cylinders are in good condition.
<a title="Bore Guage by ScooterScum_52, on Flickr" href="http://www.flickr.com/photos/brook-reams/8667618970/" target="_blank" rel="noopener"><img src="http://farm9.staticflickr.com/8256/8667618970_e599b1baf4.jpg" alt="Bore Gauge Kit" width="500" height="375" /></a>
Bore Gauge Kit
After measuring the cylinders I remove the glaze on the cylinder walls using a ball hone. I use the Brush Research Flex-Hone® with 240 grit aluminum-oxide balls that they recommend for Nikasil cylinders. I use a 3-1/2 inch hone and my portable electric drill that has a low speed range of 600 RPM which is within the recommended 500-800 RPM Brush Research recommends.
<a title="Brush Research Flex-Hone Ball Hone & Honing Oil {I Bought WAYYYYY Too Much :) }" href="https://www.flickr.com/photos/brook-reams/52110679328/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52110679328_f1fcf38cb8_c.jpg" alt="Brush Research Flex-Hone Ball Hone & Honing Oil {I Bought WAYYYYY Too Much :) }" width="800" height="600" /></a>
<a title="After Honing-Good 45 Degree Cross-Hatch" href="https://www.flickr.com/photos/brook-reams/52110643101/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52110643101_c1420d0f6e_c.jpg" alt="After Honing-Good 45 Degree Cross-Hatch" width="800" height="600" /></a>
After Honing-Good 45 Degree Cross-Hatch]
Here is a link to the document showing all the details of how I do this work and a link to a YouTube video.
<li class="page_item page-item-10228"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/11-bmw-1983-r80st-cylinder-measurements-honing/">11 BMW 1983 R80ST Cylinder Measurements & Honing</a></li>
</ul>
<strong>VIDEO: <em>1983 BMW R80ST Cylinder Measurements & Honing</em></strong>
Great job documenting this for others. Learning a lot as you step through this project. Keep up the good work and thanks for your efforts.
1983 R80ST Remove & Install Drive Shaft
I had the swing arm powder coated, so I removed the drive shaft before taking it to the powder coater.
The 1983 R80ST swing arm is designed for a monoshock rear suspension, but the driveshaft is the same as the one used in the dual shock 1983 R100RS. I previously removed and installed the driveshaft in a 1983 R100RS and documented the work.
<a title="Powder Coated Swing Arm" href="https://www.flickr.com/photos/brook-reams/49670080251/in/album-72157713519841331/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/49670080251_db4cae8a4b_c.jpg" alt="1983 R100RS Dual Shock Swing Arm Design" width="800" height="600" /></a>
<a title="Powder Coated Swing Arm" href="https://www.flickr.com/photos/brook-reams/52097391899/in/album-72177720296685752/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52097391899_c169d4d195_c.jpg" alt="1983 R80ST Powder Coated Monoshock Swing Arm Design" width="800" height="600" /></a>
This is a link to the documentation and a YouTube video showing how I remove and install the drive shaft.
<li class="page_item page-item-10262 current_page_item"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/33-bmw-1983-r80st-remove-install-drive-shaft/">33 BMW 1983 R80ST Remove & Install Drive Shaft</a></li>
</ul>
<strong>VIDEO: <em>1983 BMW R80ST Remove & Install Driveshaft</em></strong>
1983 R80ST Replace Swing Arm Bearings
I removed the swing arm bearings before I had the swing arm powder coated. The swing arm bearings are the same sealed bearings used on the 1983 R100RS that I previously rebuilt, so the procedure for replacing them on the R80ST is the same. In this document I link to the previous documentation for the 1983 R100RS as appropriate.
Here is a short video summarizing the work.
<strong>VIDEO: <em>1983 BMW R80ST Replace Swing Arm Bearings</em></strong>
Earlier versions of the airhead swing arm used traditional bearings with a separate inner and outer race. I show how to replace that style swing arm bearing here.
<li class="page_item page-item-1908"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1973-bmw-r755-rebuild-project/33-bmw-r755-swing-arm-bearing-replacement/">33 BMW 1973 R75/5 Remove & Install New Swing Arm Bearings</a></li>
</ul>
1983 R80ST Replace Push Rod Tubes
I had the cylinders vapor blasted. In preparation, I removed the push rod tubes. After they were vapor blasted I install new stainless steel pushrod tubes I got from <a href="http://www.euromotoelectrics.com" target="_blank" rel="noopener">Euro MotoElectrics</a>, who graciously has agreed to provide the parts for this charity rebuild project for free. I will auction this bike and proceeds will go to the <a href="http://www.motorelief.org" target="_blank" rel="noopener">Motorcycle Relief Project.</a>
I have done this work before on my 1983 R100RS rebuild and will reference material from the documentation of that build as appropriate.
<li class="page_item page-item-6995"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r100rs-rebuild-project-index/11-bmw-1983-r100rs-remove-push-rod-tubes-studs/">11 BMW 1983 R100RS Remove Push Rod Tubes & Head Studs</a></li>
<li class="page_item page-item-7932 current_page_item"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r100rs-rebuild-project-index/11-bmw-1983-r100rs-install-push-rod-tubes-head-studs/">11 BMW 1983 R100RS Install Push Rod Tubes & Head Studs</a></li>
</ul>
Here is what I started with before vapor blasting the cylinders and replacing the push rod tubes.
<a title="Left Cylinder Removed" href="https://www.flickr.com/photos/brook-reams/51847035170/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51847035170_3f2c21c65a_c.jpg" alt="Original Cylinder And Push Rod Tubes" width="800" height="600" /></a>
Here is a link to the documentation and a short YouTube video summarizing the procedure.
<li class="page_item page-item-10300"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/11-bmw-1983-r80st-replace-push-rod-tubes/">11 BMW 1983 R80ST Replace Push Rod Tubes</a></li>
</ul>
<strong>VIDEO: <em>1983 BMW R80ST Replace Push Rod Tubes</em></strong>
This is the final result.
<a title="Vapor Blasted Cylinders With New Stainless Steel Push Rod Tubes Installed" href="https://www.flickr.com/photos/brook-reams/52171063062/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52171063062_e2b37c2991_c.jpg" alt="New Stainless Steel Push Rod Tubes Installed In Vapor Blasted Cylinders" width="800" height="600" /></a>
Excellent, as always, Brook.
Do you have any idea when you might complete the restoration?
SPP
Pete,
Indeed, I know exactly when I'll complete this restoration: The second I'm done. :) I hope to be done in 2023, which is the 40th anniversary of the introduction of the R80ST model.
Best.
Brook.
1983 R80ST Replace And Set Wheel Bearing Pre-Load
Before I install new stainless steel spokes and chrome plated brass spoke nipples, I replace the front wheel bearings. The rear wheel does not have wheel bearings. Instead it is mounted directly to the rear drive. Since the rear wheel does not have an axle, there is no need for wheel bearings.
Here is a link to the documentation on how I do this work and a short YouTube video that summarizes the procedure.
<li class="page_item page-item-10316 current_page_item"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/36-bmw-1983-r80st-replace-wheel-bearings-set-bearing-pre-load/" aria-current="page">36 BMW 1983 R80ST Replace Wheel Bearings & Set Bearing Pre-Load</a></li>
</ul>
<strong>VIDEO: <em>1983 BMW R80ST Replace Wheel Bearings & Set Pre-Load</em></strong>
1983 R80ST Refinish, Lace And True Wheels
The R80ST has spoked wheels front and rear. In order to refinish the wheels using vapor blasting, I remove the spokes. This let me assess the condition of the spokes and spoke nipples so I can decide if I can keep most of them, or they need to be replaced.
On the rear wheel only 17 out of 40 spokes weren't bent or rusted and only 8 spoke nipples were not damaged. On the front wheel every spoke was bent. So I replace all the spokes with stainless steel spokes and install new plated brass nipples.
This documents how I do this work.
<li class="page_item page-item-10293 current_page_item"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/36-bmw-1983-r80st-refinish-lace-true-wheels/" aria-current="page">36 BMW 1983 R80ST Refinish, Lace & True Wheels</a></li>
</ul>
And this video shows the techniques I use in more detail.
<strong>VIDEO: <em>1983 BMW R80ST Lace The Spokes And True The Wheels</em></strong>
Here is what I started with.
<a title="Right Side Of Front Wheel" href="https://www.flickr.com/photos/brook-reams/51816348512/in/album-72177720295921770/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51816348512_d6521f42b4_c.jpg" alt="Front Wheel-Before" width="800" height="600" /></a>
Front Wheel-Before
<a title="Right Side of Front Wheel Hub" href="https://www.flickr.com/photos/brook-reams/51817298816/in/album-72177720295921770/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51817298816_5d13f92b08_c.jpg" alt="Front Wheel-Before" width="800" height="600" /></a>
Front Wheel-Before
<a title="Rear Wheel Secured With 3 Nuts And Conical Spacers" href="https://www.flickr.com/photos/brook-reams/51817298776/in/album-72177720295921770/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51817298776_ab2da03578_c.jpg" alt="Rear Wheel Before" width="800" height="600" /></a>
Rear Wheel Before
<a title="Right Side of Rear Wheel Showing Brake Drum" href="https://www.flickr.com/photos/brook-reams/51818013370/in/album-72177720295921770/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51818013370_cd392d0123_c.jpg" alt="Rear Wheel Before" width="800" height="600" /></a>
Rear Wheel Before
And here is what the wheels look like after refinishing them and lacing and truing the wheels with new stainless steel spokes.
<a title="All Done" href="https://www.flickr.com/photos/brook-reams/52369838748/in/dateposted-public/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52369838748_7964f3f3a2_c.jpg" alt="What All Done Looks Like" width="800" height="600" /></a>
1983 R80ST Install Engine In The Frame
At last, I get to start putting this motorcycle back together. Every time I install an engine in the frame it's a milestone. Instead of taking things apart, I am starting down the road to getting it all back together again :).
Here is a link to the documentation and the video I shot.
<li class="page_item page-item-10431"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/11-bmw-1983-r80st-install-engine-in-the-frame/">11 BMW 1983 R80ST Install Engine In The Frame</a></li>
</ul>
<strong>VIDEO: <span style="text-decoration: underline;">1983 BMW R80ST Install Engine In Frame</span></strong>
I had the frame powder coated.
<a title="Powder Coated Frame" href="https://www.flickr.com/photos/brook-reams/52375658300/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52375658300_a7381f3050_c.jpg" alt="Powder Coated Frame" width="800" height="600" /></a>
Powder Coated Frame
I use some foam packing sheets to wrap the tubes so I won't ding the powder coat when I put the engine inside the frame.
<a title="Frame Protected With Foam Wrap" href="https://www.flickr.com/photos/brook-reams/52375241946/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52375241946_bd9045b2f2_c.jpg" alt="Frame Protected With Foam Sheets" width="800" height="600" /></a>
The top is off the engine so it's lighter and easier to install in the frame.
<a title="Engine Supported With 2x4" href="https://www.flickr.com/photos/brook-reams/52375553414/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52375553414_74056cdefa_c.jpg" alt="Engine Supported With 2x4" width="800" height="600" /></a>
<a title="Engine Inside Frame" href="https://www.flickr.com/photos/brook-reams/52375658185/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52375658185_24c93c679e_c.jpg" alt="Engine Inside Frame" width="800" height="600" /></a>
Engine Inside Frame
This is the hardware used to mount the engine in the frame.
<a title="Engine Mounting Hardware" href="https://www.flickr.com/photos/brook-reams/52375553479/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52375553479_abf4173f9d_c.jpg" alt="Engine Mounting Hardware" width="800" height="600" /></a>
It's mounted on my portable motorcycle lift ready to install the top end.
<a title="Frame & Engine Mounted On Portable Motorcycle Lift" href="https://www.flickr.com/photos/brook-reams/52377537848/in/dateposted-public/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52377537848_3fe871d85d_c.jpg" alt="Frame & Engine Mounted On Portable Motorcycle Lift" width="800" height="600" /></a>
1983 R80ST Install Engine Top End
The 1983 R80ST top end is the same as the 1983 R100RS with the exception of a smaller cylinder bore, piston and rings. I already thoroughly documented installing the engine top end for the 1983 R100RS, so I reuses a lot of that material as appropriate in the documentation and the summary video.
Here is the document and video links.
<li class="page_item page-item-10445"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/11-bmw-1983-r80st-install-engine-top-end/">11 BMW 1983 R80ST Install Engine Top End</a></li>
</ul>
<strong>VIDEO: <span style="text-decoration: underline;"><em>1983 BMW R80ST Install Engine Top End</em></span></strong>
Here is what I started with and the final result.
<a title="Transmission Removed" href="https://www.flickr.com/photos/brook-reams/51840484117/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51840484117_46c7ab02b3_c.jpg" alt="The Engine Before I Removed The Top End" width="800" height="600" /></a>
The cylinders and heads were vapor blasted and I hand cleaned the engine block. I repainted the inner timing cover and top engine cover and had the frame powder coated.
Here is the engine with the top end installed. I put shop rags in the exhaust and intake ports of the heads to prevent anything from getting inside. I also put red tape on the temporary spark plugs and on the dip stick to alert me that I need to install new plugs and oil before I start the engine.
<a title="What All Done Looks Like" href="https://www.flickr.com/photos/brook-reams/52384142843/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52384142843_348edf874f_c.jpg" alt="What All Done Looks Like" width="800" height="600" /></a>
<a title="What All Done Looks Like" href="https://www.flickr.com/photos/brook-reams/52384330750/in/album-72177720296259835/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52384330750_505cd77970_c.jpg" alt="What All Done Looks Like" width="800" height="600" /></a>
</ul>
Sir, do you take projects/complete over hauls for customers? Do you ever sell the bikes you've restored or are they all for clients?
thanks, and great work on restoring the old gems
Brownie0486,
I'm an amature hobbyist. I don't do projects for customers. I've kept all the bikes I rebuilt except for this one which I will auction donating all the proceeds to the Motorcycle Relief Project. When I finish this one, I'll have to see what I do on the next project: try another charity build, or restore and sell. I haven't made that decision yet.
And thank you for your kind words.
1983 R80ST Rebuild, Refinish Carburetors
This bike came without any carburetors. I found a set of used 32 mm BING carburetors (64/32/323-324) after searching through a box of used carburetor's in one of Clem Cykowski's storage rooms. These are not the models used on the 1983 R80ST, but they will work. The date stamps on them indicate the 323 was manufactured in 11/1982 and the 324 was manufactured in 10/1982. I have to replace a lot of missing parts on the carburetors.
<a title="Useable Carburetor From R100 64/32/323-324" href="https://www.flickr.com/photos/brook-reams/51729833751/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/51729833751_c367dc6d5e_c.jpg" alt="Useable Carburetor From Clem's Used Carburetor Pile; 64/32/323-324" width="800" height="600" /></a>
<a title="Right Side Carburetor (64/32/324)" href="https://www.flickr.com/photos/brook-reams/52461745334/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52461745334_308b9edcf1_c.jpg" alt="Right Side Carburetor (64/32/324)" width="800" height="600" /></a>
<a title="Right Carburetor Manufacture Date (October 1982)" href="https://www.flickr.com/photos/brook-reams/52460961552/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52460961552_358016ed74_c.jpg" alt="Right Carburetor Manufacture Date (October 1982)" width="800" height="600" /></a>
<a title="Left Side Carburetor Number (64/32/323)" href="https://www.flickr.com/photos/brook-reams/52460988047/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52460988047_9b5d523f5d_c.jpg" alt="Left Side Carburetor Number (64/32/323)" width="800" height="600" /></a>
<a title="Left Side Carburetor Manufacture Date (November 1982)" href="https://www.flickr.com/photos/brook-reams/52462011163/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52462011163_0a9290ab25_c.jpg" alt="Left Side Carburetor Manufacture Date (November 1982)" width="800" height="600" /></a>
Here is how I do this work.
<li class="page_item page-item-10512"><a href="https://brook.reams.me/bmw-motorcycle-rebuilds/1983-bmw-r80st-charity-rebuild-project-index/13-bmw-1983-r80st-rebuild-refinish-carburetors/">13 BMW 1983 R80ST Rebuild, Refinish Carburetors</a></li>
</ul>
Here are the before and after pictures.
<a title="Parts Before Cleaning & Polishing" href="https://www.flickr.com/photos/brook-reams/52456278992/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52456278992_d4f1c288fc_c.jpg" alt="Parts Before Cleaning & Polishing" width="800" height="600" /></a>
<a title="Parts Before Cleaning & Polishing" href="https://www.flickr.com/photos/brook-reams/52457070504/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52457070504_2ed97e603c_c.jpg" alt="Parts Before Cleaning & Polishing" width="800" height="600" /></a>
<a title="Rubber Tipped Float Needle" href="https://www.flickr.com/photos/brook-reams/52457251300/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52457251300_667e7177a9_c.jpg" alt="These Carburetors Use The Rubber Tipped Float Needle" width="800" height="600" /></a>
I repainted the emblems as the white paint was missing on one carburetor and pretty dull on the other.
<a title="Rebuilt & Refinished Carburetors" href="https://www.flickr.com/photos/brook-reams/52465465790/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52465465790_7141e8be1a_c.jpg" alt="Rebuilt & Refinished Carburetors" width="800" height="600" /></a>
<a title="Finished Carburetor Rebuild-Refinish" href="https://www.flickr.com/photos/brook-reams/52461931395/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52461931395_3f2a64a7e2_c.jpg" alt="Finished Carburetor Rebuild-Refinish" width="800" height="600" /></a>
<a title="Finished Carburetor Rebuild-Refinish" href="https://www.flickr.com/photos/brook-reams/52462011318/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52462011318_56e9641fc1_c.jpg" alt="Finished Carburetor Rebuild-Refinish" width="800" height="600" /></a>
<a title="Finished Carburetor Rebuild-Refinish" href="https://www.flickr.com/photos/brook-reams/52462011288/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52462011288_715f007793_c.jpg" alt="Finished Carburetor Rebuild-Refinish" width="800" height="600" /></a>
<a title="Finished Carburetor Rebuild-Refinish" href="https://www.flickr.com/photos/brook-reams/52461745454/in/album-72177720296136177/" target="_blank" rel="noopener" data-flickr-embed="true" data-header="true"><img src="https://live.staticflickr.com/65535/52461745454_a931071c87_c.jpg" alt="Finished Carburetor Rebuild-Refinish" width="800" height="600" /></a>
