PhilStearns
Hi Guys:
I'd like to replace my front rightside BMW DIN outlet with a dual USB outlet. This one from Touratech ( https://touratech-usa.com/store/Plug-Play-Dual-USB-Power-Outlet-BMW-Motorcycles ) appears to be drop in replacement. I replaced the one on my 2019 F850GS and it's perfect. I'm told the 2018 K1600 outlet is the same as the 2019 F850 outlet.
That said, I started to remove screws and try to remove the upper right fairing panel that holds the outlet. Knowing how things go, I probably stopped one screw short of success. But after a bit and several attachment points, it didn't seem like I was loosening things up in order to get to the outlet.
Anyone ever pulled that panel or got access to the underneath of the outlet?
Thanks for any insight..........
