I've never under stood why it is standard practice to hang your butt off the seat when cornering ...But I see riders, even racers doing it well before reaching the above limits. Why?
Chicks dig it.
Thanks for your thoughtful experiences and examples of professionals who train this technique.
However I'm not convinced that it really does any good (from the hard physics perspective) for other than those who are running hard in corners 10/10s or very close!
I mentioned the 2 conditions of where I do agree it helps, running our of tread on the side of the tire due to lean angle and keeping a foot peg out of the pavement.
Moving your butt to the side, moves the center of mass of the motorcycle off (not a good thing) the vertical center line of the motorcycle. This put side loads on the wheels (wheel flex effects) and side loads on the front forks and rear suspension ( more flex effects which could lead oscillations, source of tank slappers, etc). In most cases this movement also causes the center of mass to Raise (move higher from the ground) as it is the riders mass on top of the bike that is moving. This also is not a good thing (think high side).
I do agree it gives the sensation of falling into the corner, inadvertently or more easily counter steering so for most if "feels" good.
I do not believe that the feel good benefits out weigh the negative effect of side loads and higher center of mass.
Am I missing something?
Order Lee Parks book Total Control. Read it and your questions will be answered.
Obviously you don't want to learn something from your peers on this basic topic.
Street riding should never include a need to hang off. The only time we had anyone riding with us "hang off" the guy was holding us up. We were 2-up on a K1200S.
Bob,
Relative to your two concerns; 1) modern wheels and suspensions on sport, sport touring & touring bikes are very stiff in the lateral direction and 2) shifting rider position to the side moves the CG laterally, not vertical.
As someone said in some BRC curriculum, most real world turns will be completed with a body neutral (in-line with the vertical axis of the bike) position. When needed, for road speed turns, above ~15 MPH, the added rider lean will align the rider's body CG with the inside fork tube. A 2-, perhaps 3-inch shift in position. For low speed, police style turns, the side is to the outside of the turn to counterbalance the weight of the bike.
Now, as you've observed, these modest shifts aren't the "hang-offs" some riders are doing. It's just a matter of choice. My riding area is similar to VT, so there's a few rural roads where these techniques can be fun and (IMHO) appropriate. Otherwise, it's countersteering with minor amounts of upper body lean to keep the CG inside of the bike vertical axis during a higher speed turn.
Thanks for your beneficial reply. Good info!
One small detail when the rider shift position to the side, say 3 inches, his C of Mass moves to the side describing an angle(3") for the new C of M vector to the tire contact point to pavement. If you do the math, this point ( the new rider C of M) is higher (the hypotenuse of that angle) than it was prior to the shift. So when shifting to the side, the rider must move down some how to keep the new C of M the same or lower than it was prior to shifting. This part of the reason I feel casual shifting of positions has no real benefit.
I have ordered the Lee Parks book to learn what I can from it. PS His deer skin gauntlet riding gloves are great!
Bob,
Relative to the math, let me think about it before providing a final answer. But, my initial response is, the change in hypotenuse is an arc length (L) change, not a height change, y = L cos(lean angle). To turn the bike, you want the lateral position of CG (Bike and Rider) to be displaced from the centerline, x = L sin(lean angle). So, you can maintain the same vertical height , but increase lateral displacement (x) by shifting the rider CG relative to the bike (i.e., a larger "effective" lean angle). Speed must increase to keep the bike stable at the higher lateral displacements......faster turns with a smaller bike lean angle.
When you think about this, remember shift the rider C of M (200lbs) vector does not shift the bikes (500 lbs) vector so these are no longer in alignment. (if they were your radius statement is correct). It also produces a situation where the Combined rider/bike C of M is no longer aligned with the Motorcycles' or the riders as it would be if the rider did not shift his position. Have these three C of M out of alignment enhances destabilizing possibility.
Yep, these unstablizing forces are NOT huge size( very small if riding at 3-5/10s, but seemingly totally unnecessary unless one is leaning so far to run out of tread or about to dig in a peg like racers.
Why unstablize the bike for no benefit? That is my fundamental question.
I hope Lee Parks clears this up for me.
Great point! I never thought of that.Just imagine how slow he would have been if he hadn't been hanging off in the corners.
Kurt, it was started by motorcycle racers well before Rossi was even born. I can't recall who is attributed with starting it but read an article many years ago that identified the two racers that folks argue over which one started doing it.I had heard that Valentino Rossi started doing it and others figured that if Rossi was doing it, it must help. In reality, I suspect that it doesn't really help all that much but it gives the rider some sense of where the pavement is...it just felt right. The Rossi leg wave or dangle.
but seemingly totally unnecessary unless one is leaning so far to run out of tread or about to dig in a peg like racers. Why unstablize the bike for no benefit?
Kevin, I believe this is because it is a move that originated in dirt-riding, motocross, etc. Some have incorrectly interpreted the idea as a move to have an out-rigger sort of thing to support you if you go down. Nothing could be further from the truth, although many GP racers will stick their foot leg out to the side in the wet in an effort to do just that - not very good for their ankle if they actually go down. Every sport has plenty of things that are done out of tradition or superstition that have little or questionable benefit and more to do with habit, superstition, or unfounded beliefs.In an interview Rossi said the first time he stuck his leg out was on the last lap of the first F1,500cc race he won. He was racing for the lead and fighting for position going into a corner and said he stuck his leg out to break the concentration of his opponent. He said years later Team Yamaha asked him to stop lowering his leg. He resisted so they had him do several laps in a practice session keeping his leg on the peg and then the same number of laps while lowering his leg. The lap times were essentially identical.
