Removing the clock will be some fun...you'll need to read into the fairing from the sides to undo the knurled nut and relax the tension on the bracket holding the clock in place:
http://www.realoem.com/bmw/enUS/showparts?id=0469-USA-05-1994-2478-BMW-R_100_RT&diagId=62_0248
I suspect the lens will be firmly fixed to the body of the clock by a crimped ring around the edge. It takes some skill and maybe some tools to uncrimp and recrimp the ring so it still looks OK and is water tight. There are various places that can do this work...see the speedometer section in the link in my signature line. An alternative might be to buy a replacement from various sources...I bought a replacement voltmeter for my fairing from Bass Pro...they had good instruments designed to withstand the vibration and wet environment of boats.
Thank you for your reply. It sound like it is better to replace it. I do not have the tools for this job. I’ll heading to the internet to find the replacement.
It's actually not that hard. The trick is to get a flat blade screwdriver of the correct size that allows you to "unfold" the crimp to remove the lens and cover. Reassembly is the reverse.
Do you have to remove the fairing? Aren't there some pockets on the sides of the fairing that would allow you to reach around and remove the attachments? You might have to use a mirror and a flashlight to get a sense of things, but it should be possible to do all this "blind". The knurled nut and bracket hold the clock in place. There would then be a power and ground wire...maybe a wire for lighting...they hopefully these would just pull off.
While you are in there....With the fairing off, this would be the perfect time to do this oft-ignored maintenance. Unless you know otherwise, assume that it has never been done. This is especially true on a full-fairing bike such as an RT or RS. The original grease turns to a stiff waxy substance over 35 years. With luck the bearings and cones just need cleaning and not replacement.
Russ
At the risk of playing pile-on, also consider removing the lock assembly for cleaning in solvent and lubing with graphite for the same reason. It is a 15 minute job and will make it work like new.
Russ
