I have been using Rotella T (Full Sythetic) in my 06 Wee Strom since break in (171000km!) with nothing but great results! Shifting was always smooth and the engine always purred like a well oiled kitten! I really hope to be able to use this oil in my 2016 RT but am concerned over the RTs catalytic converter! Can anyone offer any advice?
Welcome to the forum!Rotella T6 5-40 (and other grades, I think) is API SN certified, which means that it is OK to use in modern gasoline vehicles with spark ignition, and suitable for catalytic converters. Greater demand on catalytic converter lifespan was one of the main reasons for moving from SM to SN in 2010.
Jostein
Interesting....I just used some of the new BMW oil- made by Shell (who makes Rotella) for BMW. I have used 100's of gallons of Rotella in my trucks. OK, yeah, I didn't run it through my chemistry set but......all the properties that I'm used to seeing, smelling and residues leads me to believe me that that new BMW whizz-bang oil and Rotella are fraternal twins.WalMart is not the answer for German vehicles.
not sure if you're serious, but if Wal-Mart sold LiquidMoly motorcycle oil at a lower price than other places we should not put it in our bikes? The Mobil 1 full synthetic they sell is somehow inferior than the Mobil 1 Amazon or other auto shops sell and is no good for my car?WalMart is not the answer for German vehicles.
Check the March 2013 Owners News issue for an evaluation of typical properties of engine oil.
http://digital.turn-page.com/i/116570-bmwon-mar-2013
Shell Rotella T is one of the oils evaluated.
This test includes a petroleum version of a different grade Shell Rotella. I believe the OP is looking for reports of the T6 5W-40 synthetic version.
Jostein
WalMart Shell is not refined in Germany (or Dubai) as is BMW Shell. They are apples/oranges two different products.
API SN is good but you need JASO MA2 also. The friction modifiers in most auto oils can cause slippage in a wet clutch. Rosella T6 does not have friction modifiers AFIK.
JASO introduced 2 ratings for 4 stroke motorcycle oils:
JASO MA – This was the standard for single unit engines where the wet clutch, gearbox and engine used the same oil. JASO-MA oils don’t contain friction modifiers.
JASO MB – This lower standard was for bikes that use separate oils for the engine, clutch and gearbox (e.g Harley Davidson’s and BMW’s).
Then in 2006 JASO introduced…..
JASO-MA2 – This specification was introduced in 2006 for modern motorcycle engines. As well as being a higher standard of oil the JASO-MA2 approval means the oil is suitable for use in bikes with catalytic converts in the exhaust system.
Oh, and I know this is my very first post ... what is it about oil discussions that just get the fingers going ...
