If I understand you right---what the question marks represent are the images you have already loaded into the forum database. You will probably be able to identify what they are by "hovering" your mouse over them for a moment. IIRC there is a cut-off for how many images a member can uploade to the forum before some of the let's say, "older" images need to be deleted-'cause you hit the (your) limit.One more time, what to do when approximately a dozen little boxes that pop up after clicking on the paper clip? When in the past my file would pop up and I could see the pics, squidge around to the pic wanted, click it up, and then upload it.
Now, I guess, if it makes sense, the actual file numbers of some pictures are printed below the little boxed question marks?, go figure, how would I know what picture is represented by a file number, without seeing the picture? And then if dragged down below to an area labled 2?, go figure, for what?
Then above it says these dozen or so "files" in the boxes, are already uploaded in the past??
