m_stock10506
Well-known member
. Oh no! Just my luck. ............... So once I pull the panels (I assume only the left and lower valence) I should be looking for the throttle cable where it attaches to adjuster which sits on the throttle body? It sounds like the adjuster is a cradle for the throttle cable. Is that the basic idea?
If you don't perform the relearn procedure then the bike will "learn" the throttle positions on its own over time. The procedure just speeds up the process and establishes the limits of throttle position in the mapping. You don't create a problem by performing the relearn procedure.
The throttle cables attach to the throttle bodies on both sides of the bike. Either one of them could have been pulled out of the ferrule. You will have to check the cables seated in the adjuster on both sides.
