Been a MOA member since 1972-hence the 3 digit member number-but my first posting, so please forgive me if i ramble a bit. On my way to the Fontana rally yesterday my 1994 R100RT (78k miles) suddenly would not change from 2nd gear. The external linkage if fine and moves smoothly but does not shift up or down. Something internal obviously failed or came loose-feels like there is no connection inside. There were no abnormal noises or shifting issues prior to the failure to shift. All drive line fluids were changed 200 miles earlier. The oil from the transmission was clean with no debris/particles on the drain plug. Used BMW 20W50 dino oil in engine & Castrol 80W90 gl5 limited slip in tranny, drive shaft & final drive-all the same as I have been running.
Since this appears to be one of those that should have the "circlip modification" done and it has 78k miles on it, should I just figure on having it gone through instead of just the shifter repair (if that is all that has failed). I do my own light work but have never tried pulling the transmission or lubing the input splines. I'm confident that I can do the pull & reinstall but wonder if putting it into the shop would be better, so the whole bike could be evaluated. I've noticed of some good references for places to send the transmission to for rebuild. I'm close to a BMW dealer on the north side of Atlanta & about 60 miles from Apex Cycles in Ellijay, Ga. The dealer has an airhead guy & Apex got a good writeup in the MOA news some time back.
Any input from you more knowledgeable folks on what I can check or direction on what to do would be greatly appreciated.
A side issue; my voltmeter is not stable-it fluctuates rapidly most of the time. Have had no issues with the charging system not working. Don't know if I have a problem or maybe the meter is supposed to be dampened more that it is.
A plug for Platinum level membership: I called roadside assistance and about an hour later Eller's Fuel & Wrecker from Robbinsville, NC was there to pick me up (I was just south of Murphy, NC). He brought me some 90 miles home and it cost me zero dollars. What a great benefit! He was good company on the trip home as well. Kudos to BMWMOA Platinum membership and Ellers.
