Trailering and vehicle power required
Carlisle tires were mentioned earlier. They are the most common sold already mounted tires from many a big box and sporting goods outfitters.They are "cost effective" .
After losing a few on several of the trailers in our control, and thru the years on family and friend owned, I avoid them.
The failures have been on loaded, unloaded, three year old and two less than a year old. In heat and in cold. No extremes I would consider above average.
I am a trailer nut about wheel bearings and tire pressures, and these were checked on the day they failed.
We replaced the Carlisles that came on our toyhauler two seasons ago after they all wore like front tires on an RT . I stressed all the way home after seeing the tread wear.
Went to the local tire guy who shook his head at my C's and talked me into a higher end tire...MasterTracks on the sidewalls.They are 8ply class e and have taken a few long trips without any wear stresses or worries on my part.
Have other friends with same experience with C's, so I don't think I am a tire snob.
+1
In my former life I managed a Goodyear Tire Center.
Good trailer tires are worth every penny if only for peace of mind.:thumb
Given the parameters you set down in your original post (1,500 lbs. towing, not too big, etc.), again I have to say we're having a blast with our new 2014 Ford Escape.
With the 2.0 L EcoBoost in-line 4 engine, and the trailer tow prep package (w/Class II receiver), you're looking at TSC (trailer sway control - automatic), 270 ft. lbs., 240 HP and a towing capacity of 3,500 lbs.
To that, add a seamless AWD and 30 mpg when not towing.
Ergonomics and creature-features are also outstanding.
http://www.ford.com/suvs/escape/?se...20831&ef_id=VK-LZQAABA8Kv6oe:20150109130004:s
Lovin' it!
Good luck with whatever you select. :wave
That's crazy 2L, 240 HP? That's 120 HP per L. Turbo?????
I have a T@B tear drop trailer and I'm active on the forum for those critters. They weigh 1500 lbs with nothing in them and folks tow them all over the country with Subarus, Rav-4s, and every manner of small car. Do some research on the small trailer forums and you will get a lot of good info.
Yup
I use to run a stock 2.0 liter Saab turbo at about 280-300 hp, withe nothing more than a mod to the boost control.
Got to love turbo's, tons of HP and torque, and 30+mpg.
