On many of the new "racks" that is true. There are small additive tanks and both the additives and gasoline blend components are mixed right at the truck loading rack. Other refiners mix the gasoline in larger tanks and load finsihed gasoline on to the truck. Not all racks are that sophistcated and many trucks have the additive put in at the beginning of the load manually. Some refiners blend "subgrade gasoline at the refinery and the ethanol is added a the terminals before the trucks are loaded. By the way, there is legislation that is in the works mandating that the ethanol content be increased from 10% to 15%. Ethanol does have a lower amount of energy per gallon and therefore the increased ethanol mandate will lower the energy in the fuel available for conversion to the mechanical energy that makes us go down the road. The use of ethanol in fuel also competes with the food chain as corn is a major component of the worlds food supply.
