TGA57589
I pressed the start button on my 2019 R1250RT and the low beam headlights went very bright in my garage, I then pressed the start button and the motorcycle started with no issues as per usual. I noticed I had the bulb on the instrument cluster which I though was a blown bulb as per all my other BMW RT's have done. I notice riding in very dark hours of my commute that all I had was the driving lights added by the dealer from new. When I got to work all that was working was the ring lights around the low beam and the lower driving lights that were dealer added on my purchased package. I ask for some help with this issue because I have read it can be the CAN BUS system having an issue or voltage regulator. I called the dealer where I purchased asking some simple questions and he cheerfully told me I can't troubleshoot electrical issues over the phone for you. I said I'm 120 miles from you and I was hoping you could possibly discuss what has happened with other machines with similar issues. Well he said you have to bring it in.
I'm going to put it on the GS-911 to see if it can give me a code or solutions to this issue. I shined a bright light on each low beam and the bulbs look like they are good to go. I would appreciate any advice anyone has to find a solution. Thank you in advance!
