fbt80
Member
flywheel tool
I would like to insert a tool into the BMW engineers right about now.
I bought that tool from MAX BMW in prep for a future clutch install, mine is a cheap plastic 3d printed item, most likely will do the same and use it as a pattern. Didn't know if I pulled the starter I would have enough room to use it. Good tip.The 1100S uses this tool to lock the flywheel because of the airbox. The starter is removed and tool inserted.
83300401562 ENGINE LOCKING DEVICE 0.05 1 $37.32
I made my own out of aluminum
