tourists
Recently picked up a 1989 R100GS in San Francisco. I've enjoyed almost every second of GS ownership so far, it's a major step up from my 71 R75/5.
History: the bike was low-sided by the PO. It was explained to me that the crash bars and luggage took the hit. When I test rode it that story checked out the bike rides beautifully, 65mph+no hands, no problem. I was hesitant to buy a salvage bike but... you know the story .
Anyway, I rode it back to Los Angeles and immediately noticed blue on the lip of the right rear tire. The swingarm was definitely touching the tire and now maybe you could fit a sheets of paper between the two. The bike has an Wilber shock and Avon Gripster 130/80-17.
Between talking to the PO and searching around I've come up with the following:
I'd appreciate any thoughts or info on what the correct spacing should be.
Thanks!
Josh
- Send the wheel off to Woody's Wheel Works to add some clearance by adjusting the spokes and re-truing. This is the PO's advice. It feels like 2 wrongs to make the bike right to me.
- Frame straightening Seems like it will cost at least 1k to even figure out if there's a problem? I was planning on visiting Dr John's in Anaheim if I go that route.
- K bike spacer? Searching around I saw someone with a clearance issue talking about a spacer. Couple guys I talked to didn't think it would work.
Thanks!
Josh
