1983 R65, I am replacing a really worn shift lever with the new style shift lever with the bearing. Problem is the part of the shift lever that takes the bearing is .794" wide and the bearing is .627 wide. If I press in the bearing there will be gap at one end or the other. Do I just press in the bearing with an equal gap at each end or one side or the other. Confused....
thanks
thanks
