ISAMEMON
Grammarian no, Rider yes
fixing a friends leaking final drive. Mono-lever BMW.
IS there a problem with running a final drive up to "speed" for a few minutes with the wheel off and the brakes off, but the other side of the drive bolted up. so we an open it up again, and look for leakes without ruining new shoes.
I was told that a yahoo, putting a helicoil into the overflow plug drilled into the brake tube that the brake arn goes through the final drive with. They told him, 2 weks later when he went back with a big oil leak, that he needed a new final drive case, and wanted big $$$$$$$$ I told him, that if it were me, adn they put a helicoil in and screwed up the case, it should cost him nothing, but them the big $$$$$
so now I wonder if he did the helicoil and wont admit it, I havent pushed , nor will I , ask the shop who he said did the work.
thus brought to me
by the time we opened it up, it was late and it was a giant oil soaked mess. It looked like the main seal was leaking. ( at ring gear) After I lerft he did a very nice job ( anal) of cleaning everything up.( even cleaned the old oil soaked shoes) I would have prefered to take a closer look at everything as I carefully cleaned things to see where else oil might be leaking.
thus my idea of running it for a bit, without the brakes and wheel on, besides, if it still has a leak someplace , I dont want to oil soak new shoes
but I m not that familiar with the mono-shock final drive
The tranny is not loosing fluid , nor is the shaft, so I do beleive it was the main seal and maybe the brake tube ( as he was told)
my other thought is that possibally during or shortly after the helicoil was put in the final drive, that the breather got blocked, thus causing excessive pressure blowing the final seal. Or could have all been a co-incidink ( 3 stooges quote)
sorry for the long thread
thus brought to me
