Gas in Air Box!?
Sandman78
After returning from a ride this weekend, I noticed a small puddle of fluid under my bike. The puddle seemed to be mostly gas but felt like it had some oil mixed with it. When I tracked down the source it was coming from the drain hose on my air box. I removed the side cover, inspected the air box, and found a good bit of gas on the inside of the box. I'm guessing carb problems but my mechanical skills are limited so I was hoping to get some help diagnosing this problem. Any ideas on what is causing this problem and how to fix it? The bike is a '97 F650 Funduro.
Had this happen twice on a trip to Alaska. Both times the filter got enough gas in it so the engine quit. Took the carbs apart and found a small piece of dirt near one of the jets. After removing the the dirt, never had another occurance.
Go to the technical FAQs at f650.com. There is a wealth of info there. 90% you will find the answer to this problem in the "classic" FAQ
