2003 K1200RS
I apologize if there is an existing thread(s) on this subject, I did search but only came up with some general suggestions.
Can anybody direct me to a thread?
I removed the upper crossover hose that connects the left and right radiator and the lower one that connects the bottom of the left radiator to the thermostat housing on the bottom of the right radiator when I was replacing my front shock. No other hoses or coolant drains were touched.
Now that it's all back together the coolant appears to be full but the amount I put back in is 18 fluid ounces less than what I drained out.
So I have an 18 ounce sized air bubble.
I've repeatedly squeezed the hose and allowed the bike to idle for about 2-3 minutes twice with no change in the coolant level. I'm reluctant to let it idle for long imagining a big air bubble in the cylinder head....although I can't imagine how any coolant below the thermostat could have been affected by draining the two radiators.....on a cold bike the thermostat would have been closed when I drained the radiators.....
Any suggestions or other posts I could read?
