Bad news
Took the drive line loose and the problem is not there, it is inside the transmission:
Rotating the output shaft flange reproduces the catch/bump , so it is at least the rear bearing. There was more swarf on the drain plug than the last time I changed the fluid.
We pulled the transmission out of the bike and fought the lock nut on the output shaft until it came loose. The flange that mounts on the tapered shaft won't come free with the puller we have so I will try and get to the dealer in Greensboro tomorrow and see if I can convince them to take it off for me. They should have a special BMW tool for the job.
After that , we will inspect the whole works and decide if we can just replace the output shaft bearing or if it needs major attention by a specialist.
Stand by
Stand by
