vectorprime27
The short version:
DO NOT BUY GARMIN GPS ? Garmin?s MapUpdater wiped out my GPS, and now Garmin won?t fix it. Garmin response to Customer Service is as bad as any I?ve ever experienced.
The long version with all the (gory) details:
I have a Garmin StreetPilot 2820, the forerunner to the Zumo line. When new, this GPS cost over $1,000. It has been a great GPS for my motorcycle. However, I recently plugged it into the computer to update the map (I have Lifetime Map Updates for it) and the MapUpdater program wiped it out. I have to use MapUpdater because the newer program (Garmin Express) doesn?t support the StreetPilot anymore. When launched, MapUpdater immediately began to download an updated version of itself. It didn?t ask me if I wanted the newer version, it just immediately began the upgrade. Once the upgrade to MapUpdater was finished, it began the process of updating the maps for my StreetPilot. All seemed well until the GPS restarted after the update. The GPS froze at the ?Loading Maps? screen. Not matter what I tried, I could not restart the GPS at all ? it locked up at the ?Loading Maps? initial screen.
I tried to reinstal the Maps, but I could never get the MapUpdater program to connect to the GPS because the GPS froze every time it was turned on. I updated the Communicator Plugin (4.20) and manually updated the MapUpdater program again (3.3.3) to see if that would help ? it didn?t. Finally, I was able to connect to my computer where I deleted the files gmapsupp.img and gmapprom.img and this allowed the GPS to start, but with no maps (you need those for a GPS). The GPS in this state is not usable. Despite numerous tries, the MapUpdater program crashed during my attempt to installed maps ? any map - every time. I?m using Windows 8.1 64-bit version. Also ran program using Windows 7 compatibility and administrator mode. Nothing could revive the GPS, so I gave up and contacted Garmin Technical Support for help.
Garmin replied back that my StreetPilot was toast (really!), and could not be repaired. They offered to give me a 52LM or a 54LM as a replacement. Sadly, that option won?t work, and I replied to explain the problem with their offer. My StreetPilot 2820 is waterproof?necessary when using it on a motorcycle (which is all I use this one for). It also has Bluetooth - again necessary to connect to my motorcycle helmet headset. Finally, it has real buttons (in addition to the touchscreen), which can be used while wearing gloves?again, necessary for use with a motorcycle. The two units Garmin offered have none of those features, and are as useless to me as the StreetPilot is now.
Garmin replied back to that email and offered to sell me a comparable unit at 40% off. Again, not an acceptable option because to get a comparable unit, I?d have to pay over $400 out of pocket?to fix THEIR mistake! I declined their offer again and asked to be put in touch with someone who could resolve this.
Today, I got another reply basically telling me I?m screwed and Garmin isn?t going to do anything other than either give me a substantially inferior replacement, or take over $400 to fix their mistake. No matter how you slice it, this is wrong. Had I known that the update would wipe the GPS out, I never would have done it. No warnings exist anywhere explaining that (although I plan to change that). Garmin BREAKS a perfectly good GPS, and the only recourse I have it to accept a replacement unit that does not even come close to the same capability / features as the unit the Garmin broke?.OR?.I can pay over $400 (after their generous discount) to Garmin for a replacement unit.
Now in this country (world?), I?ve been taught that you are responsible to fix or replace things you break. That is a fundamental truth that even my 5 year old grandson knows. It?s not only the RIGHT thing to do, it is a matter of principle upon which our society exists. I didn?t break the GPS. Garmin?s own software did. My GPS worked perfectly until Garmin?s MapUpdater software wiped it out. IMHO it?s now Garmin?s responsibility to either repair the unit, or replace it with a COMPARABLE unit with the same features for a much more reasonable cost than the $400+ they are offering. I don?t think I?m being unreasonable here. I really expected Garmin to treat a longtime customer better.
You might want to consider this before YOU spend your hard earned money on a GPS unit. As I stated before, don?t buy Garmin. As for me, I?m going to see what other options are available.
