New Garmin Updates available
jgoertz
Member
New updates out there for Garmin Express (new version is 7.16.2.0). Latest map update is 2024.1. There may also be a software update (not map update) for some models of Garmin GPS.
Some tips for easier updates:
1) Reboot your computer to give it a chance to finish any updates that may be "hung" in never-neverland and to flush some of the buffers.
2) If running Windows 10 or 11, run Garmin Express in the Administrator mode
3) If you're having problems installing the maps directly to your GPS, install the maps to your PC, then use the MAPINSTALL option from Basecamp to install the updated maps to your GPS unit. I know there is probably a stand-alone version of Mapinstall, but I've had much better luck with Basecamp/Mapinstall to put the maps where I want them.
4) After successfully installing your map update, check the settings in your Garmin and be sure that 2024.1 is the version enabled.
5) Once you're sure that the install is good, open up File Manager and delete all the old maps that may be cluttering up your internal memory or your SD card. Look in your GARMIN/GPX folder(s) and delete all files that don't have today's date. There should only be 3 files in that folder, (you actually only need two files, both with 2024.1 in the file name. The third file with today's date and with a name consisting of a lot numbers is used for the update, and can also be safely deleted once the update has installed correctly).
Other observations made over the years: If installing in internal memory, GARMIN Express usually cleans up the old map files. Not so if installing to the SD card. With the size of the mapfiles today, you can easily run out of space on the SD card, and even easier on the internal memory card.
BTW, I updated Garmin Express on 3 different computers and maps/software on 3 different GPS units (NAVA V, Montana 660, Nuvi 2539LMT). Total elapsed time -- about 2 hours, including the reboots and using MapInstall. I only install one PC at a time!
Good luck, to all of you who, like me, still use Garmin GPS instead of telephone or the Connected App.
Good info. Thanks!
