My bike started to run funny in that when I gave it gas there would be a delay before it would start revving up. I only put about 10 miles on it and then when I gave it gas the left cylinder spark plug blew out. I limped home 3 blocks and found out that the plug threads were enlarged such that I could push a spark plug all the way in till the washer mated to the sealing surface and thus, it is going to require a Time-sert or Helicoil. I tried searching for a thread on performing spark plug thread repair but did not find anything. So thought I would post this and see what experience others have had performing this repair. I will perform the repair without removing the head since it should be easy to use grease to minimize any aluminum falling into the engine and then some blowing out with high pressure air should get anything that might fall into the cylinder. So what experience have others had with using different spark plug repair technology?
If there are some existing threads on this topic, please let me know how to find them.
