brownie0486
Well-known member
I own a 2011RT camhead and had owned a 2012GS prior.
Scenario: Cant life the bike onto the center stand, want to check oil in sight glass [ sight glass is on the port side/side stand side ].
I asked a well known boxer guru over on Advrider when I had the GS what he recommended for my situation back then in a PM. He replied and I quote him here
"On level ground, sidestand, wait 5 minutes and look. If the whole window is covered, ride. If you see any air (clear parts), add 8 ounces and ride"
That's 1/4 qt of oil if I see any "air" in the sight glass, and that's what I've been doing on both the former 12GS and now the 11RT. I asked my masgter mechanic the same question with the others advice above. He smiled and said that is perfectly acceptable Brownie. Both that GS and my RT use about 1/2 qt per 2K miles [ which my mechanic tells me is fairly normal on that motor and usually diminishes or stops after one reaches 45-50K miles on the motor ]
What are members thoughts on the advice?
