Well, part of doing your own repairs/maintenance is knowing whats beyond your capability.
I acquired a 2004 r1100s in excellent condition a couple weeks back, unfortunately, no service records.
For the most part I've always worked on my own cars and bikes, so I'm not new to this stuff.
Last weekend I changed all the fluids and adjust the valves, I was very enthused from the improvement in ride.
This weekend I was going to tackle the brake and clutch bleed.
Getting body work off was not too big of a deal, getting the fuel tank off was, one thing I don't feel comfortable working on is fuel systems so I opted to slide the tank back without disconnecting the fuel lines. Seemed to give ample access to the abs unit.
I didn't want to disconnect the electric connector to the ABS unit, so access to the bleeders was very tight. To shorten the story....brake fluid leaked when I took of the cap, so a great deal of time was spent cleaning. Then I could'n unscrew 2 of the 6 bleeders because I didn't have a socket that would quite fit. In the end I just replaced the fluid in the resevior.
After putting everything back together and installing a new air filter (that was a positive) I went to start the bike and it was running incredibly rough, upon inspection, when I slid the tank back I pulled the throttle cable out of its small housing and the throttles were now out of synch....I quickly fixed that and called my local dealer to perform a brake and clutch flush and a fuel filter change (cannot see me for 2 weeks).
Even though I have to pay for that $400-$450, I'm still way ahead since I performed the other services myself.
Next weekend, I'm going to synch the throttle bodies and by June 9th the bike will have a full 12000 mile documented service
