On my RT I always just dumped 4 quarts in and called it good.
A very knowledgeable bmw mechanic told me the motor will be fine even 1/2 quart low and a little more than called for. 4.2 quarts is 4L and isn't going to harm anything on that motor.
Worrying about nothing. If you add 4L, that's what's in the motor and what's called for.
I told him his motorcycle needs oil because he checks it so often and he is dragging oil out of the engine and wiping it off on a rag!
I get it, but some people do not!
I have a buddy that carries oil. About every other gas stop he checks his oil. If it is down one tick on the dipstick he absolutely has to add oil. I keep telling him that the motorcycle probably wouldn't notice being even more than a quart low, but he still adds oil when it needs a couple drops. His bike probably uses a 1/2 quart in 3,000 miles. He can not believe that I don't carry oil!
Finished adding the oil AND then looked at the window to see it was full. Question is: do about 8-10mls need to be removed? Oil is changed every 6k miles.
That's because the owners manual calls for four quarts not four liters which will over fill the oil sump.
The R1200RS and R1250RS owners manual shows 1.1 gallon or 4 liters.
I long for the days of dipsticks on motorcycles.
First, the procedure to check oil is to run to temp, put on center stand, and WAITE 5 mins. to read the site glass.
My manual says max oil capacity is 4L (1.1gal)
