Having a really odd problem, and it's costing me money.
I was on a day ride a few months back, and about 2 hours into the ride, I had an electrical issue that caused both headlights to blow, and the ABS and ESC lights came on solid, and both aux power sockets to turn off.
The bike kept running and there was no indication that anything had gone amiss except I had no more audio in my helmet because my Autocomm is connected to the rear aux socket. When I looked at the dash and noticed that the ABS and ESC lights were on (solid, not flashing) I pulled over to the side of the highway and shut off the power. I waited a minute and started the bike again, and all was fine except I had no more headlights as they were blown, and the ABS and ESC lights were flashing as normal, and turned off once I was rolling.
My first instinct was to replace both the H7 bulbs, which I did and parked the bike.
A week later I took the bike out for another ride of about 30 minutes this time, and all was fine at first, and I rode to my dealer to tell the service manager what had happened and see if he knew what it might have been.
He hadn't heard of anything like that before and after about 20 minutes of chatting, I got back on my bike and started it up. Within 5 seconds of starting the bike, both headlights had blown and the ABS and ESC light were on solid, and my autocomm was off again. I hadn't even moved the bike yet.
The dealer took the bike into the shop and hooked it up to the diagnostic computer which had logged a low voltage issue. That wouldn't explain all the failures simultaniously.
I got the bike back from the dealer a week later and he told me they could not replicate the problem.
I rode it home without issue and parked it. The weather turned bad and I about a month, I finally got the bike out again last weekend. About 30 minutes into my ride, no headlights, and ABS and ESC lights on solid. Pulled over, and turned bike off, then back on, and rode with my high beam on for the rest of the day and dropped it off at the dealer again.
Has anyone else had this kind of experience, and any ideas what might be causing this? What could cause all these failures simultaniously?
The dealer has the bike and I told them I want this problem gone before I get the bike back, and I am NOT paying for more bulbs!
Any ideas that I can forward to my dealer would be appreciated.
FYI, I have had the Autocomm installed on the bike for about a year without any issues, so I don't think that's the issue.
I also have a Gerbing heated liner, and Zumo 550 connected directly to the battery. I also use a battery tender while the bike is parked to prolong the battery life. Bike has always started first time.
Thanks,
Pedro.
Thanks,
Pedro.
