2009 R1200rt front brake lever working extremely hard
woody99
Member
Hi; I was riding and from the start my front brake level would hardly move, not applying the front brakes hardly at all. I rode for maybe 75 miles just using the back brake. We parked for an hour and on my trip home the front brake worked normally.. Does anyone ever experienced they or heard of this. I have rode for almost 60 years and never experienced this? Thanks Woody
Just a WAG - some debris blocking a line or blocking one of those teeny little holes in the master cylinder...?
I'd expect some kind of fault code...
Some issues may deserve a wait-and-see attitude. In my opinion a situation where pulling the front brake lever resulted in "applying the front brakes hardly at all" is not such an issue.In normal riding the front brake usually does 90% of the braaking. Lacking that, in an emergency stop, the rear brake is very likely to cause the rear wheel to slide. The results easily include hitting something, skidding into a low side, or being tossed in a high side.
This is an issue which needs to be resolved proactively; not re-actively.
This doesn't seem like a "bleed" issue - if a bleed fails, the level pulls all the way in with little or no resistance; his issue is a "hard" lever.
But maybe it is a "crud" issue and bleeding/flushing may remove the crud. That is where I would start, at least.
Bypassing the ABS
Does anyone have info and parts availability for bypassing 2009 R1200rt ABS system, I ordered a master cylinder rebuilt kit, but if that doesn't work? I seen some bypass videos on you tube on older bikes. parts from UK. Any ideas
2009 hard brake lever
I took apart the front brake master cylinder and there was no snap ring, just metal piece, I talked to a BMW mechanic and he said they made it so it was not repairable, anyone dealt with this before?/Users/Woody/Desktop/Brake.eml/Users/Woody/Desktop/Brake.eml
hard brake lever
We ordered a front master cylinder kit for the Boneyard.. I disassembled everything and found something no one seemed to know about, The master cylinder did not have a snap ring holding in the piston. It had a slotted piston with a pin in the middle of the reservoir, a clasp was holding the pin in place, once that was removed the pin that was holding in the piston ,it slide out. Weird setup. The kit from Beemer Boneyard was not right, but the rubber seals worked./Users/woodymiller/Desktop/IMG_2538.jpg/Users/woodymiller/Desktop/IMG_2540.jpgIMG_2538.jpgIMG_2540.jpg
