RANBUSH
Ran Bush
I rode my 1994 K75S around town in early October this year, and I noticed it died at a couple of stop lights, which is unusual for this bike, but it started right back up and I rode home. I went out to ride it last month and it cranks and cranks, but it won't start.
I did some research on the interweb and saw quite a few posts on this topic; one said, "turn the key on, hit the starter, listen for the fuel pump". I did that this weekend and I swear I didn't hear anything, and I saw no movement of the fuel in the fuel tank.
Tried this again today, and when I hit the starter, I hear the fuel pump, and see fuel moving around. Engine cranks but won't start, fuel pump apparently working, but may be intermittent.
My buddy Greg suggested squirting starting fluid in the air intake for a few seconds - no joy, won't start. He suggested pulling apart the four-pin connector to the fuel tank on the right side of the bike. I swear I saw 12V on three pins with the key on, and then the second time I tried it I saw no power on any of the pins (one of them is ground). Greg suggested putting a timing light on one of the spark plug wires, hit the ignition, and see if the timing light lights up. No joy, no response on the timing light.
Lots of fuel in the tank, checked fuses, all good. Horn and lights, battery charged up, all good.
Lee Fulton pointed me to an excellent troubleshooting flow chart from Bertrand Vogel in the DIY Forum here.
I plan to pull the fuel tank tomorrow and check to see if the Fuel Ignition relay is getting 12V. Any other ideas?
