Hi all
Just to be clear, the hinged oil filter that I am about to install on a 1978 OIL COOLER INSTALLED R100RS has an attached black seal on one end and not on the other. The seal end goes in first correct? On the thermostat end of the oil filter there isn't a seal. The thermostat/ cover first gets the black gasket, then the smaller diameter back seal, then the white o ring and then the metal shim. Is all of this correct? Thanks all
