bandersnatch
Hi all,
After waking up my R90/6 after a 25-year slumber I'm in the process of getting it road ready. While tearing down the front wheel for new tires and spokes I ended up with a few questions.
1. Wheel bearings. They seem fine, spin well with no grinding and appear to not have any significant wear on the rollers or roller surface. Should these be replaced as a matter of course, or would you all clean them up and re-use? Also, the bearing surface inside the hub appears to be pressed in, if the consensus is to replace bearings and associated bits, is tapping them out from the back side the proper removal method?
2. Upon disassembly, I found the rotation arrow on the rim was pointed backwards (opposite the rotation of the tire). I don't know the history of the bike, but it appears completely original and I don't have any reason to think the wheel has been worked on previously. Could it have come from the factory that way or is it a DPO error? Not an error? Very confused on this one . . .
3. The center hub appears to be symmetrical, true or not? In other words, if I send it out to be media blasted (it's quite ugly right now) and my left/right markings get cleaned off is there a way to tell which side is right/left or does it matter?
4. How is the rubber wheel bearing seal installed? It appears to be pressed in, but from the front or back side? Being rubber, I want to replace them (as well as the thrust ring as they do have some grooves scratched in them) but don't want to destroy anything by improper removal.
Thanks in advance,
Larry
Thanks in advance,
Larry
