Thanks for the tip. Just did mine this afternoon. Looks soooo much better.[/QUO
Well post a pic. Let us see how good it looks
Ask and ye shall receive!
Has range and/or quality of reception changed?
I recently researched this.
As your photo clearly shows, the diameter across the threads of the mount for the antenna rod is smaller than the diameter of most aftermarket (and car) antennas. It's 10 mm and I went across to the car side of my BMW dealer and measured a Z4 antenna and that diameter is 15 mm. I think basically no eBay or Amazon blurb indicates the diameter and of course none of the sellers indicate BMW motorcycle fitments. If there's a car with the more "petite" antenna it would be great to know the brand. Having the antenna rod larger than the mount as is noticeable in the photo wouldn't work for me.
If somebody finds or has found a stubby replacement the "correct" size, please post about it.
You're right. I guess I'll go put a few wraps of electrical tape around it to smooth out the transition.
I put an 8mm screw with a rubber grommet in the antenna socket.
Me too ... and I never use it either, as I only listen to Sirius and that's a different antenna.Personally, I think it looks just fine and it works great
