What to do with the Antenna ??
mosrrt
Got a 2015 RT and it has a radio. Ok, but the ugly antenna has got to go.
Any one replaced it with something else or just removed it ?
The times I have had antennas on my bikes, the first thing I did was take them off and replace them with a short 'rubber-duckie' antenna. They come is 'short' sizes. You can get them at any auto part store and onLine. Usually, they come with several bolt size connecting options and you ought to find one to stick on your bike well enough.
I found their reception to be about on par with the long OEM antenna.
The problem I always encounter was that when throwing a cover over the bike, the antenna tends to get bent up and eventually break.
This time, I was lucky enough to find an RT without a radio (the way I wanted it).
Antenna
Check out Amazon.com and search for Shorty antennas. They make several of them that screw right on the replace the stock antenna and cost about 12 bucks. I put one on and it works just as good as the Stock antenna. Looks better too. GT
Ask and ye shall receive!
Has range and/or quality of reception changed?
Couldn't tell you. I use my iPhone for all my music. If it does affect reception I'll swap it back. Provided I ever listen to the radio.
I mean, for $10 and 15 seconds of install time, it's the most can't lose farkle I've ever done on a motorcycle.
I recently researched this.
As your photo clearly shows, the diameter across the threads of the mount for the antenna rod is smaller than the diameter of most aftermarket (and car) antennas. It's 10 mm and I went across to the car side of my BMW dealer and measured a Z4 antenna and that diameter is 15 mm. I think basically no eBay or Amazon blurb indicates the diameter and of course none of the sellers indicate BMW motorcycle fitments. If there's a car with the more "petite" antenna it would be great to know the brand. Having the antenna rod larger than the mount as is noticeable in the photo wouldn't work for me.
If somebody finds or has found a stubby replacement the "correct" size, please post about it.
You're right. I guess I'll go put a few wraps of electrical tape around it to smooth out the transition.
I do not use the radio. I just took the antenna off, put it in a clear plastic tube from Ace Hardware to protect it, and put it in the top case, where it will reside. I put an 8mm screw with a rubber grommet in the antenna socket.
antenna replacement
bought a mini antenna for 10 bucks at auto zone. 3.5" part # aw-rmrm by raptor accesories needed adapter that came with it to make it work fitwise it looks and works great no one else had it tried all the parts stores
Replacing the antenna doesn't even make the list of things that I may change.
Pete
