I agree- I'd contact Corbin. Assuming there is no damage otherwise to the tank or its fitment on the bike, I think the seat should fit fairly flush against the tank. My low seat does…Not that it will be of much help, but I have a Corbin on my K75RT and there is no gap between the seat and the tank. It fits right up against the tank. It would appear that seat is made for a different bike, or a different model of K. A picture sent to Corbin might solve the mystery.
Usually on the underside of Corbin seats is a sticker that lists the fitment. Check and make sure it isn't for a 1985, they were different and not interchangeable with other years.
Gene V.
No such thing as an '85 K75. K100 yes. K75 no. But it could be an '85 K100 seat.
Just trying to think outside the box - Is the gas tank seated properly with the little clips on the posts? I don't see the rubber tank pad on the rear of the tank, but even with that installed, I don't think you'd make up the room. There is some slight adjustment available by moving the seat latch around so you may able to get closer if Corbin says you've got the right seat. The older K seats came with the handles in the seat, so you would have ran out of room if you had an older K seat, as they are longer.
That model is a Rumble, the Smuggler model didn't have the fold up backrest.
Oops! You are correct. It's been so long since they made those for a K that I "misremembered" what they called them. I see they brought them back for Harleys and a couple of other bikes. Thanks for the quick correction.
That's not an '85 seat, but if you are using it with a low seat tank the fit will not be great.
