oil in the airbox?
H
HMushman
There's a 1/4-turn plug at the left rear underside of the air box on my '03 1150R. It has an O-ring seal on it. I noticed today that it appears to be leaking oil, actually found a small drop on the ground in the garage. I removed the plug and cleaned it off, but you really can't get a good look into the hole it plugs. I removed the air filter and, while it is 10K old and needs replaced, it wasn't totally clogged or anything. The bike has been running fine, no smoke on start-up or unusual oil consumption. I did just return from a 1200-mile weekend.
Why would there be oil in my airbox? Should I be concerned? The bike has 19,700 miles on it and was just dealer-serviced for the 18,000-mile tune-up a few weeks ago.
-Kennet
ItÔÇÖs not uncommon to have some oil in the air box. Most oil heads have a screw at the bottom of the air box to drain some of the oil that collects in that area of the air box. This oil is part of the crankcase ventilation system and BMW's plan is to vent it inside the breather. Even the old Air Heads have a similar system. I have a R1100S and usually each oil change I drain any oil that has accumulated within the air box.
Not to worry! :thumb
Tomas
That's normal. The plug is a drain for oil that collects over time from the breather. If oil didn't collect there, they wouldn't have designed a drain plug.
No big deal, the dealer probably got the oil full. It will migrate to the Airbox. Be glad it was just a drop or two when you took that plug out. it is part of the pcv system on the bike, and some have reported a fair amount of oil there if they have overfilled the crankcase with oil.
"whew!" (a sigh of relief)
Awesome, thanks for setting my mind at ease everyone! :D
-Kennet
It ia not uncommon. Check and drain it when you change your oil. My 02 50R, in the first 10K sucked oil into the airbox. It has stopped with no good explination. It did somehow allowed some oil to spill into the intake and turned the bike into a high priced two wheel bug sprayer. Live and learn, but do not worry.
