PeoriaMac
the dreaded dual plug answer
OK, David said what I was going to say...only better.
So, Grrl, if your bike "pinging" on high test gasoline? Perhaps maybe only on hard excelleration?
The solution, back in the day, was unleaded valves (the lead in 'regular" gasoline provided a measure of cushion to the valve seats) and/or dual plugging. Or...thicker base gaskets to lower the compression.
Remember, the higher the octane number, the LESS easy the gasoline is ignite.
Dual plugging allows for a faster flame front so one can advance the timing slightly.
Thicker gaskets resulted in a lower compression ratio, allowing the use of a lower octane gasoline.
I went the dual-plugging route, and added electronic ingnition. Never regretted it. Then again, it's a lot more expensive now.
BTW, if the answer to those first to questions is "no'....don't do anything.
Mac
Mac
