Hello Airheaders-
I posted the following on the R65 webpage but so far have failed to receive any feedback, hoping someone here can provide some commentary.
I recently purchased a 1980 R65 (build date 11/79) with approx 37k miles. I have read that the clutch/flywheel assembly was redesigned on the R65 for the model year 1981, which resulted in a lighter flywheel and modified clutch parts resulting in a better shifting experience. I’m curious to know if the difference is significant between the ‘80 and ‘81 models. And if so, is it possible or even worthwhile to update the clutch to later specs if needed. I recall lightening the flywheel for my ‘79 R100RS in an effort to improve gear shifting with marginal success, but unsure if this is the same issue.
Thanks in advance for your thoughts!
Tom
Tom
