2012 R1200GS "Burnt Oil Smell"
jgp1854
A bit of information first:
2012 R1200GS - 6.5K miles - purchased used with 2.5K miles. At 3K mile I changed the oil, oil filter, transmission fluid, and final drive, primarily to replace all the drain plugs with "DIMPLE" plugs. During the process, I found the dealer overfilled the final drive, the drain totaled (215cc). I refilled to 180cc. Over the next 3K miles the engine oil has dropped less than 25% of the sight glass. I had the BMW dealer performed the 6K mile service recently, but not the oil, oil filter change, I did that myself.
ISSUE:
Right from the onset of my acquiring the 12GS, on occasions when I'd come to a stop, I could detect the odor of burnt oil.
WHAT I'VE DONE"
I obviously monitored the oil consumption and IMO the drop in the sight glass was NORMAL. I examined the drain plugs, oil filter, bone dry. I examined the engine the best I could and for the life of me cannot find anything that would point to an oil leak.
I searched some forums, and found a threat about the "cam tensioner bolt" not being torqued properly from the factory. I looked at the bolt with a light and mirror, and found no evidence of weeping oil.
I called the BMW dealer and asked about the cam tensioner bolt being the culprit, he said, in his three years, he has only seen 2 units that the cam tensioner bolt was not torqued properly.
QUESTIONS:
If the cam tensioner bolt was not properly torqued, and the oil smell is coming from it, wouldn't I see some visible sign of weeping?
Based on the aforementioned information, what other possible avenue or areas can you advise I look.
Thanks in advance.
Regards,
73516
Michigan
It's pretty easy to wind up with two oil filter gaskets on these bikes since it's easy to overlook the fact the old gasket separated from the existing filter when it was removed and remained "stuck" to the engine filter flange. Two of these rubber quad rings together can create a leak source.
Kent
Thanks for the reply, I made positively sure all gaskets were removed. When I removed the filter, I noted it being stuck to surface area. I removed it, and wiped clean the surface area prior to installing new filter.
thanks
73515
Look carefully for any sign of minor seepage that has gotton on the exhaust. A drop of oil on top of a cat-con can make a lot of smoke and stink. The culprits are usually a little seepage at the engine crankshaft seal or transmission front shaft seal - which eventually finds its way down to the exhaust.
I have the same problem. After my 12k service, I noticed a burnt oil smell whenever I came to a stop. Took it back to the dealer and they insist there is no leak. It has to be coming from somewhere.
One thing to keep in mind about R1200s
Draining tranny fluid without getting some on the pipe is a bit tricky. I suspect most shops don't worry about it and just wipe off what they can- in which case the remnant will stink until it burns off.
Locate the tranny drain plug and follow the likely drip path to the pipe to inspect for this.
Paul
Thank you for your reply. I checked the cat/conv zero sign of anything on it.
73516
Racer7
Long ago I got a tip to address specifically the point you are making. The tip is to take tin foil and fashion a trough to direct the tranny gear lube from the drain plug to the drain pan. It works perfectly.
Thanks for your reply.
73516
FYI,
If you visit Advrider forum you'll find many GS owners that have the same issue.
73516
Had a similar experience...
With my '12 RT. I didn't think too much about it because I knew there was no leak as there was no detectable dripping. I simply wrote it off as the the typical oil consumption known for low mileage R bikes.
There was the slightest amount seeping out from around the oil fill plug and the valve cover bolt seals on the same side that has stopped. I also suspect some of the smell was attributed to the oil that passes the rings, especially when running the engine at higher revs for longer periods.
Smell has completely stopped and consumption slowed. I currently have a bit over 10k miles, couldn't be happier.
I wouldn't sweat it. The bike has a warranty, use it when/if you need it.
Scot
Kent
I've responded to Dave's comments, waiting for his response.
The forum is a big part why I belong to BMWOA, amazing brain trust in its membership.
Thanks to everyone.
Regards
73515
Michigan
A trip to the BMW Dealership:
the service manager took a flexible LED light and looked over the engine and found nothing that would indicate any sort of oil leak. Which was precisely what I determined on my own. His comments were: the oil level might be a bit high, which I disagreed with. When I changed the oil, I intentionally limited the oil refill to less than full sight glass, and that was apparent upon his examination. BMW, suggests 4qt when changing the oil and filter. When the dealership did the 600 mi service, they clearly filled the oil sight glass with out any open space, so I presume they used all 4 qts. He also, said the engine oil will find its own level, and suggested something about it leaking via the pistons thru the exhaust?????? The odor continues and appears to be stronger. But again, no leaks, nor oil loss being noticed. So at this juncture I'm at a LOSS as what to do. He further noted I've got 36K and 2 years left on my warranty, which is accurate, but not very reassuring as to their ability to diagnose this issue.
If you can provide me advice I certainly would appreciate it.
73516
Paul,
Thank you. Your wealth of knowledge and experience is reassuring. I will today, drain that amount of oil that will bring the level down to the center of the glass (COLD).
73516
I just got back from a nice little 200 mile ride. Burning grasshoppers smell a lot like oil. They must be kind of greasy. They are thick this year. If you have them where you are then there is a possibility. If you have oil collected in your air box from overfilling, it can drip out and smell. Oil from the road can be thrown up on the pipes. One of many bad smells from riding in the heavy fog this morning. Wet grasshopper road gunk combo. My garage reeked for about 30 minutes.
Rod
Paul,
73516
From my owner's manual:
Engine oil Checking engine oil level
The engine can seize if the
oil level is low, and this can lead to accidents. Always make sure that the oil level is correct.
The oil level varies with the temperature of the oil. The higher the temperature, the high- er the level of oil in the sump. Checking the oil level with the engine cold or after no more than a short ride will lead to misinter- pretation; this in turn, means that the engine will be operated with the incorrect quantity of oil. In order to ensure that the engine oil level is read correctly, check the oil level only after a lengthy trip.
Check that the engine is at op- erating temperature, make sure the ground is level and firm and place the motorcycle on its centre stand.
Wait five minutes after switch- ing off the engine at operating temperature.
If the oil level is below the MIN mark:
Top up the engine oil
If the oil level is above the MAX mark:
Have the oil level corrected by a specialist workshop, prefer- ably an authorised BMW Mo- torrad dealer.
Oil cold, bike on centerstand, top of oil at dot in middle of the sight glass.
Paul
thanks again for your insight. I took your advice and pulled exactly 6oz of oil from the GS, which brought the "cold" oil level to the middle of the sight glass. Took the bike out for a run, the oil smell is still present?????
I'm not comfortable with the perspective of just letting it run its course and see what happens, nor am I thrilled with the dealership not taking a proactive approach to help remedy this matter. So if you have other suggestions that I can try, I'm all ears.
thanks
Jim
73516
Michigan
PONCH1
Thank you for your reply. My current GS is my 10 BMW motorcycle over 35 years, and am very well versed in checking the oil.
Mr. PGLAVES, if you aren't familiar with him, is one of the foremost authorities on BMW motorcycle repair in the country. His reply is directly linked to the comments by the BMW dealership's service manager about the oil being potentially to high. When Mr. Glaves speaks people need to listen. He has forgotten more about diagnosing mechanical issues on BMW motorcycles than many of the "certified master mechanics", currently in place.
I use this forum for valuable input from many of its members, and again I would like to say thanks for their input.
73516
PONCH1
73516
Yeah, I am familiar with his sainthood, he's the veritable pope of BMW.
