K
KLENNOP
Servo brakes?! On an R1100S Boxer Prep? I have the exact same bike, '04, but no servo brakes. Would like to ask where you got the "tank" side pads?
Sorry to get this off topic but I figured I could quickly answer Andy. There are actually a couple different versions of the R1100S in 04. Earlier versions were different such as light models and so weren't the 05 Boxercup Replika's.
If it has ABS in 04, then it has the servo brakes. Also the Replika and Preps have the sport shock, the spring will be yellow and not blue(some people swapped them out). The Replika's also came stock with the Laser Exhaust(the 2 into 1 model).
In 04 you could have the following options:
Boxercup Replika with ABS and Heated Grips and 5.5" rear rim
Boxercup Replika without ABS but with Heated Grips and 5.5" rear rim
Boxercup Replika without ABS and without Heated Grips with 5.5" rear rim
R1100S Prep without ABS without Heated Grips with 5.5" rear rim
R1100S without ABS with Heated Grips with 5.5" rear rim (have seen it!)
R1100S with ABS without Heated Grips with 5.5" rear rim.
R1100S with ABS with Heated Grips without 5.5" rear rim. (Mine)
There are a couple of odd balls in there also that seem to come up here and there but these are the ones I know for sure.
I wanted to switch to the 5.5 inch rear rim on my bike but it is really hard to find a yellow one. Then I thought of having a silver one powder coated to match but BMW made some small changes through out the years that make some of the rear wheels not match up correctly. Plus the wider the rim the slower the turn in and out of turns. I am not at racing caliber yet so the 5" of rim isn't affecting me yet. Plus you can drag your cylinders with either rim!
I don't remember where I got my pads but I think they are CSS. They come with the sides, and one that goes in front of your junk.
If you have any other questions, PM me just so we don't jack this guys thread anymore, OK.
