2001 R1100R, 7000 miles. Cannot figure out why my bike will not crank. It turns over, fuel pump is working, but it just will not crank. I removed the tank (a 3rd time) to remove a newly installed AF-XIED and used a posi-lock connector to reconnect the O2 sensor wire. AF-XIED really works great but was having an issue with a rough idle when cranking the bike after it was warm. roger04 is helping me out with the issue. Did some checks using a DVM and possibly a bad O2 sensor. I checked the wiring twice on the AF-XIED and it was right. Planned to run the it without the AF-XIED in order to see if the same issue exist. Anyway, bike cranked fine before the most recent tank removal. I put everything back together and it turned over, cranked, but immediately cut off. Now it just turns over and won’t fire up. I disconnected each fuel line quick disconnect and reconnected. Bike then did the same thing. It’s like a switch somewhere is disconnected or something. The entire fuel delivery system in the bike was replaced ~ 7 months ago and the it has never done this before.
