JCBR1150R
boxergrrlie said:I recently bought an XM receiver and will be setting it up on the bike soon. Meanwhile I use it in the car and at home.
At home, I have the antenna in a window facing South/Southeast and the reception was perfect for weeks, so I ran the wires down into the basement and up into my stereo cabinet. It's a nice, clean installation.
However, two days ago the reception started getting dicey and it is terrible now. It will be a bit of a PITA to reroute the wires so I wanted to see if anyone else had a similar experience. Is this just a part of XM? Do I need to expect to move the antenna periodically?
TIA
I have the Sirius Sportster R and eventually got the home kit. I have aimed the antenna and like you the reception is dodgey and eventually stops all together. You need to keep in mind that this signal does come from a satellite in the atmosphere that may or may not maintain it's speed in orbit around earth and the azmuth could change as well. Due to these variables, the signal comes in and goes out of range.
The home kit antenna, like the car antenna, is supposed to be weather proof, so I will mount the joker on the roof and see if that makes a difference.
