gsadennis2015
where can i find a wiring diagram for my 2015 gsa? https://forums.bmwmoa.org/images/smilies/headscratch.gif
I have a Haynes manual 6281 that has a color one.
Jay
It sounds like you are looking for a switched power source. If you have something like the Clearwater canopener it is easy to get to a switched power source. You would use this, perhaps with a dash-mounted hardware switch, and a relay to provide power to the aux lights.
I have used the headlight low beam on k75s bikes (yellow wire) to get the switched power, thru a hardware switch and relay to power aux lights. A relay and fuse would be recommended for any aux lights.
If you get to the rally without getting the aux lights hooked up, I'll bet you could come by the airheads tent and someone will be able to help you set up your aux lights.
Should be:
Blue/Black: Right turn signal
Blue/Red:Left turn signal
Grey/Red: Tail light
Grey Black with Yellow dot: Brake
Brown: Ground
The Haynes manual for 2013 - 2016 BMW R1200GS motorcycles is available here -
https://haynes.com/en-us/bmw/r1200gs/2013-2016
One can purchase an on-line subscription for around $20 and print selected sections.
That is the only wiring diagram that I know of for wetheads.
