motodan
Well-known member
'08 R1200RT winter project now needs heated seats hooked up. Stock seats had been replaced by a Sargent's heated seats which have proprietary connectors. I've gone back to a stock seat, so now I have BMW connectors on seats and Sargent connectors on bike. Trying to go cost effective route I requested two connectors from Sargent's to put on seats. However after two weeks and a couple of calls these "free" connectors have not arrived. So thinking of removing both BMW and Sargent connectors, to go with a 2 Pin Quick Disconnect Harness, which has a standard SAE plug on each end of 12" wiring....cut in half - one lead each seat/bike...make for easy connection. Will need a separate 4 wire connector for rear seat. Question is, since leads are for heated seats, will difference in wire gauge create any problem? The quick disconnect wiring is 16 gauge, seat/bike wiring is smaller gauge, the BMW brown ground wire size. Thanks
