I bumped my old thread. 1. to see when i replaced this battery before. 2. to be confusing.Like Omega man said above, you probably want to throw an ammeter on it when cranking.
I didn't know it had been replaced, so my bad.![]()
Back in the day, jumping was a pretty straightforward solution. But with all the electronics on today’s bikes it is a much more risky procedure. Still possible, but mind the electronics. Bump starting used to be a good option too, but today’s bikes need enough battery on board to energize the fuel pump, ignition system, and ECU and with a flat or very low battery one can’t generate enough electrical oomph to do that at bump-start speeds.To all: Not sure on this bike, but can't he jump start this battery? I know if his charging system is bad, he might not make it home, but at least he'll know.
Which leads to another question, can he bump start it?
Gotta get some zots to run the fuel pump, which can make it tricky. I've push started a K75, if memory serves, though.To all: Not sure on this bike, but can't he jump start this battery? I know if his charging system is bad, he might not make it home, but at least he'll know.
Where is this positive connection? Got a photo? The starter is on the left, no? Where else would there be positive power? And can you get to it without tools?NOTE that if you take it to your FLAPS for testing, they typically will want to put a "quick charge" on it first.
Tell them NO - you want to see its condition the way it IS NOW, not the way it is after topping off them 'lectrons.
And yes, the 1150 can be jumped; if one is lucky, there will be a Positive connection point just ahead of the seat and to the right of center, and a big ground post on the rear of the left cylinder., or at least a convenient large grounded bolt head.
The starter is on the left side. It is inside of a plastic cover, right behind the clutch housing. The main power lead for the starter runs directly from the battery to the upper big lug on the starter solenoid. When the solenoid is magnetically energized by the starter relay it engages and connects the current to the starter motor by way of the lowwer lug on the starter solenoid. That plastic cover is held in place by a single torx head capscrew on the side and two rubber covered pins that extend forward into holes in the clutch housing . The heavy wire at the top connector on the solenoid is a direct positive connection to the battery.Where is this positive connection? Got a photo? The starter is on the left, no? Where else would there be positive power? And can you get to it without tools?
Ok that's all good to know.The starter is on the left side. It is inside of a plastic cover, right behind the clutch housing. The main power lead for the starter runs directly from the battery to the upper big lug on the starter solenoid. When the solenoid is magnetically energized by the starter relay it engages and connects the current to the starter motor by way of the lowwer lug on the starter solenoid. That plastic cover is held in place by a single torx head capscrew on the side and two rubber covered pins that extend forward into holes in the clutch housing . The heavy wire at the top connector on the solenoid is a direct positive connection to the battery.
Some of the bikes are equipped with a "post" that connects to that hot starter connection and which extends horizontally through a hole in that plastic starter cover. If so, the post can be connected to with a positive +12v wire or cable. If the bike is not so equipped, then the starter cover can be removed and a positive jumper connection can be made directly to that top connector on the solenoid.
This is directly true of the R, RS, and GS models. I am not sure whether the RT models have the starter cover as described. If not, the connections at the starter solenoid are the same in any event hidden by the fairing.
Maybe check for a loose connection at the battery terminal while you are in there?Ok that's all good to know.
I carry a torx screwdriver with me. I'll pop that cover off to get familiar in my own garage.
I just got a Westco battery for my airhead and I'll pull that and install.
Reading your signature line, the 81 R100 uses a 28AH battery and the Oilhead uses a 19-20AH battery. The 28AH battery won't fit.
Yeah I found that site but it's doesn't show duralast, which Autozone sellsSomething like this?
Battery Lookup | 2002 BMW R1150R Motorcycle Battery
Battery Lookup has aftermarket batteries compatible with the 2002 BMW R1150R. This Motorcycle originally came with a Yuasa 51913 power sport battery. The repwww.batterylookup.com
