k7gle
Member
This will probably turn into a "doh!" after I get the first answer, but I'm used to being wrong (married 35 years) so here goes:
What is the purpose of the second HES 180 degrees apart from the other? Both plugs fire at the same time, based on the one at 360, right? It seems the Motronic could calculate RPM and crank position based on just one. Is it just to provide a higher resolution calculation?
