26667
the Wizard of Oz
When replacing the exhaust system, (whole thing, from the head pipes to the exhaust) do you work from front to back? i.e the head nuts, to the rear motor mount nuts, then to the two bolts in the rear of the frame? Or vice-versa?.....? or is there a pattern like when torquing the head nuts?
I've also got a Brown side stand that slightly alters the left rear motor mount.
Having seriously and repeatedly perfected the synch/ balance of the carbs and set the valves. I tried removing and replacing the exhaust to locate the cause of the annoying footpeg vibration. It seems pretty clearly to be in the exhaust mounts. I just loosend all the connections and pushed and wiggled the exhaust and the problem lessened. I don't know what part of the process did it, but it helped. I can now at least find a couple of mph / rpm combinations where she runs smooth
