Well, if the ABS system lights go out when the bike has exceeded about 3mph then the signal strength from the sensors is ok. But I suppose you could check the sensor coil for continuity, since all it is, is a wire wrapped around a core. If you were to probe between the two connector pins on the sensor harness you should get continuity or a very low resistance value.
If you get a high resistance value, or basically an infinite ohms reading, then the sensor would be "open" or bad. I do not have any value for the resistance of a good wheel speed sensor.
If you could attach a voltmeter to the sensor connector wires and then spin the wheel, you should get an AC voltage ouput, though I have no idea what that value would be.
