Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Yes - but - you will need four new bolts. There is a 5mm difference in length. I forget which is which but one wheel needs 55mm bolts and the other needs 60mm bolts. Measure the bolts you take out and then get 4 of the other size. Ignore the center hole in the K1200 wheel.
There's a 5.0" wide and allegedly a 5.5" wide K1200LT wheel, the 5.0" will fit an R1100RT, with the appropriate bolts as Paul said. The 5.0" wheel is part 36 31 2 331 909. Wheel bolt is 36 31 2 333 225, 55mm. The spacer is the same.
Michelin says it takes a 160/70R17 which is a touch taller than the stock 18" tires.
I tried the Metzler bias ply ME880 for tire life and it was almost unrideable - way too stiff.
I also tried a Continental ContiMotion tire because it was cheap, that rode fine.
The K wheel is a 5-spoke and doesn't match the front wheel, if that bothers you. Not really noticeable behind the bags.
Of course you may crash and burn because this is not an approved modification, try at your own risk.
