johnson92@msn.com
When I increase the throttle it zeros out the speedo, and when I let off the throttle it recovers.
The speed sensor on the R1100s is on the rear drive housing, directly behind the brake caliper. If the bike has ABS there will be two sensors on the rear housing, you want to look at the rear most sensor, the front sensor is for the ABS.
