Welcome to the Wethead accessories and mod index thread. With the well received introduction of the Wethead, we at the forum find ourselves in a position where we can start making a list of accessories and modifications from the beginning of a model introduction. We at the Moderator Team hope this will be of benefit to the current and future owners of the water cooled BMW.
There are some real nice threads to start off with and will continue to add and adjust categories as the members present their work to the forum.
For luggage, racks, and carry/packing systems try-
http://forums.bmwmoa.org/showthread...ing-the-R1200GSW-AltRider-Luggage-Rack-System
https://forums.bmwmoa.org/showthrea...e-rack-on-2020-RT1250RT&p=1228053#post1228053
For electrical accessories, batteries and driving lights and Shindengen SH847 voltage regulator, try-
https://forums.bmwmoa.org/showthread.php?103522-Shindengen-SH847
http://forums.bmwmoa.org/showthread.php?69915-Adding-accessory-socket-to-GS-W
http://forums.bmwmoa.org/showthread.php?77158-2014-RTW-HID-Headlight-Installation
For frame/chassis, suspension, fuel and seats try-
http://forums.bmwmoa.org/showthread...R1200GSW-The-AltRider-Sidestand-Enlarger-Foot
http://forums.bmwmoa.org/showthread.php?69956-Fuel-Filler-Mods
http://forums.bmwmoa.org/showthread...e-R1200GSW-AltRider-Skid-Plate-and-Crash-Bars
http://forums.bmwmoa.org/showthread.php?72269-2014-RT-Suburban-Machinery-DL3-Drop-Peg-Kit
http://forums.bmwmoa.org/showthread.php?74127-Wunderlich-engine-bars-on-2014-R1200RT
http://forums.bmwmoa.org/showthread.php?76880-Radiator-Guard-Idea-for-the-R1200-GSA-wet-head
http://forums.bmwmoa.org/showthread...nd-light-bracket&p=987089&posted=1#post987089
http://forums.bmwmoa.org/showthread...on-a-14-R1200GSA&p=989147&posted=1#post989147
http://forums.bmwmoa.org/showthread...on-a-14-R1200GSA&p=989150&posted=1#post989150
https://forums.bmwmoa.org/showthrea...thead-Install-Pictorial&p=1087717#post1087717
https://forums.bmwmoa.org/showthread.php?90260-Shifter-Linkage-Lube&p=1104535&posted=1#post1104535
For a general "show and tell" of the new "Farkles" that you have added, try-
http://forums.bmwmoa.org/showthread.php?69018-Wethead-GS-Farkles-Post-them-here
http://forums.bmwmoa.org/showthread.php?77232-What-have-you-done-to-your-Wethead-today
http://bmwdean.com/r1200rtw.htm
http://forums.bmwmoa.org/showthread...ender-Extender&p=1060176&posted=1#post1060176
For removal of the Wethead Bodywork and Air Filter service check the JVB video-
http://forums.bmwmoa.org/showthread.php?76025-Wethead-Bodywork-and-Air-Filter-Video!
http://forums.bmwmoa.org/showthread...dywork-and-Tank-Removal-Install-YouTube-Video!
http://forums.bmwmoa.org/showthread.php?84224-2014-R1200GSAw-Bodywork-and-Tank-Removal-Install-Video!
For bodywork fastener sizing, removal and washer replacement try
https://forums.bmwmoa.org/showthread.php?92506-Fasteners&p=1135035#post1135035
If you would like to see a walk-through of the GS911, one of our Members has created one.
http://forums.bmwmoa.org/showthread...ng-a-GS-911-for-basic-scheduled-service-tasks
For final drive spline lube and fluid change-try
http://forums.bmwmoa.org/showthread...ube-Pictorial!&p=1038176&posted=1#post1038176
For a DIY on how to adjust engagement distance for the clutch or brake- try
http://forums.bmwmoa.org/showthread...e!-(pictorial)&p=1039493&posted=1#post1039493
For tires and wheels including tire inflation monitoring devices- try
https://forums.bmwmoa.org/showthread.php?89225-TPS-Battery-Life
https://forums.bmwmoa.org/showthread.php?96706-YouTube-R1200RTW-TPMS-Programing-with-the-GS-911
For threads that reference the maintenance schedule(s)- try
http://forums.bmwmoa.org/showthread.php?85724-RT-Maintenance-Schedule-From-BMW-Rider-s-Manual
For a 12000 mile maintenance video Thanks BoxFlyer! Try
For help with the Wethead Cam Chain Tensioner Tool Thanks again to BoxFlyer!
If some of the BoxFlyer videos are not accessible from here, PLEASE try the BoxFlyer YouTube Video Channel!
The BoxFlyer YouTube Video Channel- Videos on DIY Maintenance.
https://www.youtube.com/channel/UCeJAqO8pJpydWQ4z6iNOs9g
Looking for the hard to find tools for working on your Wethead, Try-
forums.bmwmoa.org
Just in from BoxFlyer, more videos to keep your 1250 running smooth-
Here's the Overview of the tools needed for doing the 12k Service on the 1250.
Here are the series of videos for doing Cam and Valve checks on the 1250.
First is number 1 of 4 parts of the actual 1250 Left side Cam Alignment Check followed by 2 of 4 which is the Left side Valve Clearance check.
After that 3 of 4 is the Right side Cam Alignment Check and finally 4 of 4 is the Right side Valve Clearance check.
https://youtu.be/aqXLQXiaMXQ
https://youtu.be/G8rTKzbPuBg
Motor32 has posted informational videos on his new 2023RT
Comparison between his '20 and '23- https://forums.bmwmoa.org/showthread.php?103576-VIDEO-Comparing-My-20-RT-To-My-23
Adding a Skeen brake (flash) system- https://forums.bmwmoa.org/showthread.php?103597-Video-Adding-Skeene-Brake-Flasher-to-my-23-RT
Retrofitting a Werks winshield to the new bike- https://forums.bmwmoa.org/showthrea...rks-Quiet-Ride-Windscreen-To-Work-On-My-23-RT
Adding road light covers- https://forums.bmwmoa.org/showthread.php?103592-Video-Road-Light-Covers-23-RT
We will endeavor to keep this updated but remember, these are ideas from our members!! If you have an idea, don't be shy - take a few pictures, add a few words and help give a boost to the owners of this fine new bike.
If you see a thread that should be added or need a little help with your posting, just contact a Moderator and we will take a look. Thanks to all that made this part of the forum a "go to" spot for the Wethead.
The Mod Team.
Boxflyer Cam Timing Tool Kits NOW Available!
Hello, 2024 brings some exciting changes as it relates to the availability of my Cam Timing Tools and Kits. I’m pleased to announce the transition of production and availability of the Boxflyer Cam Timing Tools to fellow board member Joe Pilz! @machinejoe Joe is an avid BMW Rider, and along...
The Mod Team.
