After doing some work on my R100 and painting the VC, I'm getting a leak. When I bought it a month ago it didn't leak. I did a valve adjustment and tested it. Leaked considerably. Next, I had the heads off for pushrod seals so it's all been apart. I measured a small gap when I put the VC on with no gasket. I reinstalled last night and test fired the bike (didn't ride it) for a few minutes. I cleaned them really well and added a little #2 seal. I added to the head side (glue side). Which might have been an error.
In reading I hear that the head/glue/printed side is supposed to fuse itself to the head after some time. Also that maybe some oil should be applied. (It's self oiling in my case!)
Am I just impatient? Should it take more time than 5 minutes of running in the garage? I'm betting there's a little warpage of the head (esp on the left).
I'm not above adding a second gasket (someone did this for my old bike). In that case do you put sealent between the gaskets? I'm not.looking to go to the silicone version yet.
Thoughts?
Thoughts?
