Using the High Beam Circuit for a Relay 2017 R1200GS
akbeemer
SURVIVOR
Can any one offer any advice on identifying and gaining access to the high beam circuit on a 2017 R1200GS? I wish to use it to power a relay for auxiliary lights.
:lurk
I'm thinking the CANBUS will growl at that Kevin. I'll be interested in how it works out :thumb
Gary
I’ve used CanBus circuits to power relays in the past. Relays demand such small amperage so as to sneak under the CanBus radar. In this case I’m hoping not to have to employ the hunt and peck technique to find the circuit.
On my Hexhead GSA, the relay trigger is on the high beam so they come on when I hit BRIGHT. Have not caused an error code on display.
It is such a low draw, doesn't bother CANBUS logic.
I recall going thru the little rubber boot vent on rear of housing and posi-tap to rear of bulb socket with slack for bulb changeouts
Now, north of I-40 I have no guarantees:wave
I’m concerned that having LED lights may complicate the issue, but I will try tracing the wire from the high beam switch to a convenient location and see if that works. Will be on the lookout for a white wire.
Forgot you have that fancy new fangled lighting. Are there no more access covers as well? Haven't dealt with Wethead lighting yet.
Look at the actual socket at the bulb. Confirm wire color (white since God was a Cub Scout) and trace backwards to a good connect point.
